03-22-2023 01:55 AM - last edited on 03-22-2023 04:35 PM by computergeek541
Hello,
Yesterday I paid $25 for my plan and today I upgraded and paid $40 for the new plan.
Could you issue the refund for the $25 plus taxes back to my account as the difference is less than a day.
Needed extra data.
03-22-2023 06:25 AM
@Eliza5 PM is a prepaid provider, usually do not provide refund
It is a normal behaviour to charge full plan price of the new one and NO partial refund of the old plan if you selected "Change plan now" option.
You can try to ask PM support nicely and explain that you missed that. There is a slight chance support can do something but it is really YMMV.
03-22-2023 05:29 AM - edited 03-22-2023 05:30 AM
As the others have indicated, it's a stretch, but maybe you will reach a supportive agent who sees things your way.
03-22-2023 02:48 AM
03-22-2023 02:04 AM
Doing immediate plan changes forfeits the previous plan. There is no pro-rating or refunds for doing so for most prepaid providers. What you should have done was to set up the plan change for the next renewal. But here you are.
Or is it that you used up the 1gb and all the freebie data leaving you with nothing making you want to get the more data.
Maybe, since it's only been one day, support might be able to do something nice for you. But if you used all your data then I doubt it.
