01-02-2018 12:36 PM - edited 01-04-2022 03:13 PM
When i pick a plan, is there any other charges associated with plan like 911 fee or other fees that will be added to bill? For example, if i pick $20 plan, final bill will be $20 +tax?
01-02-2018 02:37 PM
@bluesuzuki06 just follow this its will work fine
I found this info posted by @Luddite:
- do not use the same email address for Kood and Public Mobile
- do not request the port-in during activation; take a temporary number, log out, confirm all services are active, log back into your account and select Transfer Number under Change Phone Number
- do not use any identifier except your Koodo account number; it is always the best item for any port-in request
- do not make any errors in the Authourized User; this must be exactly as it appears on your Koodo bill
- do not use the person's Koodo number as the Alternate Number; use someone else's
- do not forget to click "I am authourized ...." BEFORE you entering your Koodo number
Thank you
Solved!
01-02-2018 02:30 PM
@bluesuzuki06 yes but first open your account with a new number after that you will port your number
01-02-2018 02:28 PM
Currently with Koodo, and would like to keep same phone number. Sounds like i will be able to?
01-02-2018 02:03 PM
@bluesuzuki06 wrote:1 more question, can you transfer your old number over to Public Mobile?
@bluesuzuki06 what is your old privder, its not the same how to tranfer
01-02-2018 02:02 PM
@bluesuzuki06 go ahead with refer your famaly make shure to add your phone number when thay open ther account
01-02-2018 01:57 PM
@bluesuzuki06 yes, you can. Either during activation or after activation (with new number). Your current account must be active in order to port in.
01-02-2018 01:50 PM
01-02-2018 01:45 PM
Thanks for the quick feedback everyone. I'm going to buy plan for my father in law, and if good, i think my wife and i will switch over too. Almost seems too good to be true.
01-02-2018 01:27 PM
@Rabbi wrote:@bluesuzuki06 i see you have the $20 plan just you let you know tace the 90 day plan with autopay you will end up at $18 +tax for 30 days
& after 5 years you will pay $13 for 30 days
& start to reffer freinds you can end up like me to have it for free your phone
01-02-2018 01:25 PM
01-02-2018 01:23 PM
@bluesuzuki06 pm is a prepaid plan and extra charge is only tax (in qc its gst/qst - the total will around $23) no other fees like 911 or other
01-02-2018 12:49 PM
At Public Mobile the 911 is included in your plan price.
All prices are before tax
01-02-2018 12:44 PM
@bluesuzuki06 wrote:When i pick a plan, is there any other charges associated with plan like 911 fee or other fees that will be added to bill? For example, if i pick $20 plan, final bill will be $20 +tax?
Correct, just the taxes for the province of your phone number. If you use autopay, or get other rewards, they are subtracted before you pay.
