Plan Expired, Service suspended
Madigurlz
I've recently purchased a public mobile top up for $25 wich is the price of my current plan but the service is still not active. ive tried to talk to a rep but only get the machine
1 REPLY 1
will13am
@Madigurlz, did your top up work?  You should see it as account funds.  If the funds are in, try using the reactivation button.  It may take a bit of time for it to work.  If you are unable to restore the account to active status, you will need to contact the moderator team for assistance.  The moderator team can be reached via private message using this link.  Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
