Options
08-12-2024 01:32 PM
I'm just looking for confirmation regarding the 50GB CAN-US $39 plan, will calling, texting, and data be useable within the US or will a roaming add-on still be required with this plan? Thanks.
1 REPLY 1
Options
08-12-2024 01:37 PM
@DeeGee01 no roaming add-ons will be required. With the Canada-U.S. plans you can roam in the U.S. as if you were in Canada, you can make calls, texts and use data with no hidden fees. Just be sure to have Data Roaming turned on and that you are connecting to either T-Mobile or AT&T
