06-29-2022 10:42 AM
06-29-2022 10:44 AM
@tarapada this is a common browser glitch, something to do with cache
Try using Incognito mode, or use another browser (Edge/Chrome/Firefox) or clear cache and restart
You can also try to use another device
06-29-2022 10:45 AM
@tarapada Hi clear your cache change browser use ingognito mode reboot and try again
06-29-2022 11:20 AM
Thanks folks - but if I change my plan the day after billing, does it bill/refund according to new plan right away or next month?
06-29-2022 11:25 AM
@tarapada wrote:Thanks folks - but if I change my plan the day after billing, does it bill/refund according to new plan right away or next month?
@tarapada It depends if you clicked Change plan now or Change on the next renewal date
If you don't see the new plan, now, you likely have clicked Change on the next renewal date. It is the BEST choice if you make that request a day after your new cycle. Change Plan now would have let PM charges you a new plan immediately, your old plan with 29 days remaining would be wasted.
Keep you current plan now and let it change on the next renewal date to minimize the loss. make change on the day you cannot survive on that old plan anymore, you can click Change plan now at that time. But do keep in mind, any remaining days of that current cycle would be forfeited
