Pixel 8 pro
JattVett
Is the pixel 8 pro volte supported by public mobile
@hTideGnow wrote:
hi @JattVett
yes, the Pixel 8 is fully supported here and also work with VoLTE, someone talked about this earlier
and basically all Google phone since Pixel 6 are supported here
The list provided by Public Mobile says:
  • Google Pixel 4/4XL/4a/4a 5G (TP1A.220624.014 & above)
  • Google Pixel 5 (TP1A.220624.014 & above)
  • Google Pixel 6a (TP1A.220624.021.A1 & above)
  • Google Pixel 6/6 Pro (TP1A.220624.021 & above)
  • Google Pixel 7/7 Pro (TD1A.220804.009.A2 & above)"
I've seen VoLTE working at Public Mobile on a Pixel 4 XL.
@hTideGnow wrote:
hi @JattVett
VoLTE works on even older pixel phones.  I got it working on the 4a 5G.
hi @JattVett
Phil_Adelphus
@JattVett   It should be, although it's not on the VoLTE list that list doesn't get updated and typically a newer version of something already on it should work.
https://www.publicmobile.ca/en/on/get-help/articles/volte
