07-12-2023 01:28 PM
I have been reading the past posts on resetting or even finding your pin password for your account and when I go on the APP under Account Security Info (as suggested) I only see Voicemail Password - no PIN Password. I have also tried on the website and I only see Voicemail Password as well . I must say this website is not very well organized for users- it is hard to find My Account.
07-12-2023 03:31 PM
Ok, then turn on wifi (not wifi calling) and try calling the number you were trying. It seemed odd to me that that would interfere with your calling.
07-12-2023 03:29 PM
yes turned off wifi calliing. Thanks for all your help
07-12-2023 02:42 PM
Thanks so much
07-12-2023 02:42 PM
Wow thank you
07-12-2023 02:41 PM - edited 07-12-2023 02:42 PM
It's in the subscription area of payments. Does your phone show an option for wifi calling? If so then turn it off. There's no wifi calling here.
Adding - wifi calling, not just wifi
07-12-2023 02:41 PM
to update the credit card, go to Payment page, then Manage Subscription and the Update payment method
@ArtsyT Go to payments page / manage subscription and then manage payment method
Adding or use this link to it @ArtsyT
https://myaccount.publicmobile.ca/en/account/my-payment/manage-subscription
07-12-2023 02:39 PM
Tried calling with wifi off and that worked. Yeah!! So I will get the UK add on but I need to change my credit card details and I have been circling around my account, payments, profile etc and can't find where you update the credit card info. Thanks for all of your support. Will research this issue.
07-12-2023 02:05 PM
@ArtsyT It shouldn’t have dropped but wifi calling not supported by PM so wifi should have any affect on that . Try with just phone wifi off maybe . That or this another question for support
07-12-2023 01:59 PM
I tried the 011 52 ... and it rang through and then the call was dropped. I have full PB bars and I am on wifi so it should go through
07-12-2023 01:55 PM
I was using +52
07-12-2023 01:54 PM
@ArtsyT And for Mexico are you 011 52 then contact
07-12-2023 01:54 PM
Okay so there is another add on for that country. I called Mexico too and no go - told I did not have enough minutes.
07-12-2023 01:53 PM
Which add-on did you buy? The above is the 300 minute. No UK. You'd need the other UK add-on to call there.
07-12-2023 01:51 PM
Mexico and the UK
07-12-2023 01:48 PM - edited 07-12-2023 01:50 PM
@ArtsyT What country are you trying to call ?
adding
Countries included in international long distance include: Australia, Austria, Bangladesh, Brazil, Chile, Colombia, Czech Republic, Denmark, France, Germany, Greece, Iceland, Ireland, Israel, Italy, Japan, South Korea, Malaysia, Mexico, Netherlands, New Zealand, Norway, Peru, Poland, Portugal, Puerto Rico, Romania, Singapore, Spain, Sweden, Thailand, Venezuela. Calls must originate from Canada. Any unused minutes will roll over to your next cycle.
07-12-2023 01:46 PM
Thanks Handy1 I have tried refreshing, logging in and out but when I go to make an international call it tells me I am out of minutes. I have sent a message to an agent, just waiting for a response. Thanks again
07-12-2023 01:44 PM
Not yet I will follow up directly with an agent Thanks
07-12-2023 01:44 PM
@ArtsyT Double check that like this
Try again incognito/private mode
And or lap top /computer
OR
simply try refreshing the page to check data plan / mins / add ons
07-12-2023 01:43 PM
Thanks Handy I will do that. I also bought an add on yesterday that I have no access to, so I think my account is not fully migrating in my purchases.
07-12-2023 01:41 PM - edited 07-12-2023 01:41 PM
@ArtsyT That’s odd please contact support to investigate that . You should have 4 digit PIN code for 611 and for verification purpose
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
VVVVV Link below VVVVV
07-12-2023 01:39 PM
Thanks Handy1 When I go to the link and log in I only see Voicemail password on the page. See attached. I have made note of the link though which is helpful for quick access to my account
07-12-2023 01:34 PM
Any luck with the links provided?
07-12-2023 01:33 PM
Hi Dust2dust I just signed up and yes you have identified why I want to find the Pin
07-12-2023 01:30 PM
How long have you been here? I have read of that option not being available. Maybe they removed it for new sign ups. The substantial problem with that is that then they can't use the 611 service for anything other than basic info.
07-12-2023 01:29 PM
@ArtsyT Use this link to it and tap pencil next to pin and you can change it to what ever you like
07-12-2023 01:29 PM
