07-18-2016 04:01 PM - edited 01-04-2022 02:51 PM
I've never been able to send or receive pic messages with PM, but I could with Koodo. My daughter set my APN as per the instructions here and my data is on. Ive tried my sim in another phone and it still doesn't work. Anything else I can try?
04-22-2019 12:03 PM
This method still works fyi. Just saved me with my difficult setup of the zenfone 4 max after Android update. Picture messaging is now working with these added settings.
Cheers
08-02-2016 01:01 PM
It seems my picture messaging has stopped working again. I have not changed any settings, my data is on, I've restarted my phone and I've only used 3mg of my 1gb of data. Any ideas what else I can try?
07-20-2016 07:04 AM
I had the same problem. Solution- Make sure your data is turned on. To receive a picture message it has to have data or it will not come through . I like to save my data for something important so I turn my data off. When i receive a picture message or want to use data i turn back on.
07-19-2016 09:39 PM
07-19-2016 04:37 PM
You rock as always!!!! ![]()
07-19-2016 04:33 PM
07-19-2016 11:54 AM
@b1791, some people have reported success by entering the following:
APN Type: default,mms,supl
Also, you must be on the data network and not on wifi when you send a test mms. Hope this helps.
07-19-2016 09:12 AM
07-18-2016 09:07 PM
07-18-2016 08:08 PM
Hi @b1791!
I can see from the image you attached that your MMS settings are not fully filled in.
The MMSC line is not supposed to be blank.
Please click on the link belove and compare your APN settings to the ones on that page, fill in the missing lines and save. Reboot. You should be able to send/receive MMS after that.
07-18-2016 07:52 PM
07-18-2016 07:49 PM - edited 07-18-2016 07:51 PM
Here it is.
07-18-2016 04:41 PM
Can you send us a screenshot of your APN settings?
Thanks,
Shazia
07-18-2016 04:39 PM
I saw an issue like this caused by the phone resrticting the size of images. However, given that regular texting is working and that the same error occured in a second phone, I think it's something Shazia will need to address.
Keep us posted.
Good luck.
07-18-2016 04:28 PM
My phone is an HTC 320. My daughters phone is an LG G3
07-18-2016 04:23 PM - edited 07-18-2016 04:23 PM
What's the make & model of your phone?
07-18-2016 04:21 PM
I have international texting and text all the time. Just can't send or receive picture messages.
07-18-2016 04:19 PM
I'm sorry to hear about this,
Would you be able to send me your Public Mobile phone number via private message? I will gladly assist you further.
Thanks,
Shazia
07-18-2016 04:16 PM
Just to be sure, log into your self serve account and see if you have texting in your plan.
If so, since the same problem occurred with the sim in another phone texting has not been added. @Shazia_K?
