Picture messages
04-23-2020 05:32 PM - edited 01-05-2022 10:30 AM
04-24-2020 09:49 AM - edited 04-24-2020 09:52 AM
@CharChar_xxo Try these
APN settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,supl
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: Not set
MVNO value: Not set
Use the 3 dots top right of your screen to save it. Enable data and try sending an mms message and surfing the internet.
Stay safe
04-24-2020 09:45 AM
Do you know what i need to change settings to?
04-23-2020 08:54 PM - edited 04-23-2020 09:18 PM
- Drag down the notification bar and tap the Settings icon at the top-right.
- On the Networks tab, tap More. ...
- Tap Mobile networks.
- Tap Access Point Names.
- Edit the settings.
- Tap the 3 dots top right of your screen select Save and exit.
Enable data and Try surfing or sending an mms message.
04-23-2020 08:49 PM
How do i find apn settings
04-23-2020 08:45 PM
Then it's your apn settings, see type 3 below.
Stay safe
04-23-2020 08:42 PM
I did a factory reset when i got the phone then added my PM sim into the phone. I have no issue with regular texting
04-23-2020 08:40 PM - edited 04-23-2020 08:43 PM
@CharChar_xxo LG phones require at minimum a network reset and sometimes a factory reset to work properly on PM.
LG G5 - Reset Network Settings
- From a Home screen, navigate: Settings. > System > Reset. ...
- Tap Network settings reset.
- Tap RESET SETTINGS.
- Tap Reset Settings.
After enable data, restart your phone reset your APN settings if required.
04-23-2020 08:40 PM
Got the phone second hand when i moved to canada. Got it unlocked so i could use the phone with public mobile. I can use the internet
04-23-2020 08:38 PM
Lg 5
04-23-2020 05:50 PM
@CharChar_xxo wrote:Hi it is on
If your data is turned on and you are still having issues here is a great site to setup your APN and instructions on how to do it. Find the APN Settings for Public Mobile here!
04-23-2020 05:49 PM
@CharChar_xxo has data worked on your phone previous to this?
04-23-2020 05:49 PM - edited 04-23-2020 05:50 PM
Great. And has it ever worked here or are you just new or is this the first time you've tried here? Can you otherwise browse the internet?
04-23-2020 05:46 PM
Hi it is on
04-23-2020 05:37 PM
@CharChar_xxo what's the make and model of your phone? Thanks.
04-23-2020 05:36 PM
@CharChar_xxo wrote:Hi i cant send any picture messages and im not sure why
@CharChar_xxo Data needs to be on for MMS to work. If your data is on then check your APN settings to make that APN type contains mms.
If you have an iPhone make sure you have enabled mms within iMessage.
04-23-2020 05:35 PM
Is your cellular data turned on in your phone?
04-23-2020 05:34 PM
@CharChar_xxo Did you enable data on your phone?
04-23-2020 05:34 PM
@CharChar_xxo hi you must have your data on to send or receive mms
04-23-2020 05:33 PM
Have you ever been able to here with Public Mobile?
