Phone
Des71
unable to use phone it tells me I need to make a payment. I have autopay.
HALIMACS
Hi @Des71
It sure sounds like the auto-pay may have failed.  Were you charged the amount for your plan on your payment card - check recent transactions to confirm.   If not, make a manual payment on self-serve sufficient to cover the plan amount such that the necessary funds display in your "available balance", then click the 'reactivate' button to get service.
If that's not the issue, you might try the following troubleshooting steps:
  1. Make sure airplane mode is off
  2. Power OFF your device, wait 1 minute, turn on and check for signal bars
  3. Check on account self-serve that your account status is "Active"
  4. While on self-serve, check that SIM card number under “Change Sim card” matches the SIM card number in your phone
  5. Make sure you’re in a covered area and there are no cellular outages
  6. Change Wi-Fi calling preferences to Cellular Preferred or Cellular Only
  7. Set network mode to Auto
  8. Reset network settings
  9. Update device software to latest version
  10. Perform a manual network selection
HEllo @Des71 What does your account status say in your SELF SERVE account? https://selfserve.publicmobile.ca/
Triguy
You can also make a payment using recharge.com or ding.com but there a service charge.  Some people have a cash balance in their account in case autopay fails.
hairbag1
Dial 611 to get account status and make payment to Reactivate.
Double check to make sure your credit card / debit card hasn't expired.
kb_mv
@Des71 Sounds like your autopay failed. Go into your self serve and make a manual payment to reactivate your service.
