10-24-2020 04:07 PM - edited 01-05-2022 03:53 PM
08-24-2021 10:33 AM - edited 08-24-2021 10:34 AM
@Joaniebaby wrote:Hello
You mentioned about contacting PM when u buy a new phone, how do you do that?
What is your ?. Do already have a new phone or do you want to buy a refurbished phone from PM?
08-24-2021 10:30 AM
Hello
10-24-2020 09:11 PM
10-24-2020 06:15 PM - edited 10-24-2020 06:23 PM
Hello @joreilll ,
Yes as @ShawnC13 posts.
If you change your phone at anytime, you do not need to contact Public Mobile to let them know of the change. Obtain other compatible phone, insert the SIM inside your current phone and you are good to go.
NOTE: there are possible different size SIM that each phone requires. If yours is a different size than the other phone you want to change to, no worries.
They come in 3 in 1 sized:
If you need a small one: punch out to the size you need.
If you need a larger one: try going into a cell phone store/kiosk and see if they have the outer parts you need to make it bigger to fit your phone.
10-24-2020 05:29 PM
@joreilll...
be cautious if buying a used phone from kiji or other similar venue. There's many sellers who are less than honorable and you could be left with a brick. Make sure the phone you buy hasn't been reported as lost or stolen and blacklisted...rendering it useless to you.
Good practice is to use a retail supplier or a used/refer'd phone supplier who is known to be legit.
10-24-2020 04:19 PM
Sure you can upgrade it, if your phone is a few years old I’d hold off on it unless you can budget for a new one. As long as your new phone is compatible on the network PM won’t stop you from upgrading. Just make sure the phone is unlocked when you buy it.
10-24-2020 04:10 PM
@joreilll wrote:I want to upgrade my phone, can i?
Of course, you can, just not through PM as they don't offer phones. Make sure any phone you choose is compatible with the Telus/Bell Network and you will be good to go.
