Phone
03-10-2020 08:13 AM - edited 01-05-2022 09:52 AM
hi I just activated my SIM card yesterday I can make a call but I can't text.
Joining Public
03-10-2020 03:57 PM
@gblackma wrote:@computergeek541 , Oracles, please merge these thread. Thanks.
https://productioncommunity.publicmobile.ca/t5/Getting-Started/Phone/m-p/511867
done, thanks
03-10-2020 09:13 AM
so you have trouble with send or receive the text, if you only can receive the text and cannot sending out, maybe because you run out all the text if you enroll in the $10 plan. If not this case, you need to see if your phone have problems.
03-10-2020 09:13 AM
@ToniPaul83 , your sim did not provisioned correctly. Contact the moderators and ask them to reset your SIM. Click on the green questionmark in the white circle at the bottom right of your screen. This connects to the autobot Simon. Type moderator and follow the prompts to get to one. (CLICK on account specific question and human and submit a ticket)
@ToniPaul83 wrote:I cannot send or receive texts
03-10-2020 09:11 AM
03-10-2020 09:10 AM
@ToniPaul83 can you send and not receive texts? Thanks.
03-10-2020 09:08 AM
My data works as well
03-10-2020 09:07 AM
I can make a phone call.
03-10-2020 09:06 AM
Still having issues texting:(
03-10-2020 09:00 AM - edited 03-10-2020 09:05 AM
@ToniPaul83 Can you send and not receive texts? Its a all a symptom of a stuck port. The answer is the same. Either call the Telus porting department or contact the moderators, as mentioned in your previous posts.
@ToniPaul83 wrote:Hi my texting is not working I took out the SIM card turned off the phone put the sims card back in and turned the phone back on still not working.
03-10-2020 08:58 AM
Does your talk and data work?
Is your plan active?
Is it SMS texts or MMS texts not working?
Maybe try to toggle airplane mode on, then off (this re-connects to PM network). Network reset?
Can also try the SIM card in another phone. To help determine whether it is hardware issue versus PM service problem.
03-10-2020 08:56 AM
03-10-2020 08:35 AM
03-10-2020 08:26 AM
Hi I just rebooted my phone to see if my texting would work and it never worked. I and using my same number from my old provider. Yes I transferring my same number.
03-10-2020 08:24 AM
You can also try logging into your self-serve portal to verify your account. Just to verify that all is in order. From there you can setup your autopay and your referal code to give to your friends!
https://selfserve.publicmobile.ca/Overview/
Hope your issue gets sorted out quickly.
03-10-2020 08:17 AM
Ok I'll try rebooting my phone
03-10-2020 08:16 AM
@ToniPaul83 try restarting your phone. You may have a stuck port, or an incorrectly provisioned SIM. Contact the moderators and explain your situation. Click on the green questionmark in the white circle at the bottom right of your screen. This connects to the autobot Simon. Type moderator and follow the prompts to get to one (CLICK on account specific question and human and submit a ticket)
@ToniPaul83 wrote:hi I just activated my SIM card yesterday I can make a call but I can't text.
03-10-2020 08:14 AM - edited 03-10-2020 08:17 AM
Did you port your phone# from another provider ? Try rebooting your phone.
If you are having trouble with your services, the next step is to contact a moderator. Here is the link to create a ticket through SIMon:
https://www.publicmobile.ca/en/bc/get-help -> Click on Chat with Simon on the line "ask me something" write "moderator" -> then click on "account specific question" -> afterward click on "no, I want a human" -> finally you will see an answer "submit a ticket Click me!"
