Phone transfer error
Claudette_B13
I need help to get my phone working! Would someone please respond to my problem!  I made an error entering my Bell Mobility transfer number and although Public Mobile sent me a text message welcoming me, my cell phone is not working. I cannot make nor receive calls.
@Claudette_B13
Please note that your old Bell SIM will continue to work until porting is completed.
This may take up to 2 hours to complete. Once your phone will indicate SOS then power off the phone and switch to PM SIM.
@Claudette_B13
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins.  If you are not receiving calls and text on your PM sim card, and only outgoing calls work, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
When you call and if the system not picking up the number, message support at:
Chalupa_Batman
The Public Mobile chatbot is currently unable to create trackable tickets for members who are unable to log in. So for this reason, please use the following link to contact them.
