03-02-2023 06:18 PM - last edited on 03-02-2023 06:24 PM by computergeek541
While I can get texts, whenever I try to call someone it says "number invalid". When someone calls me it never goes through. This just started this afternoon
03-02-2023 06:48 PM
I'm receiving calls but can't make any. 6UM1 message that the line's no longer in service.
Tried restarting phone, airplane mode, restarting again, manually selecting network, auto selecting.
Very strange
03-02-2023 06:24 PM
hi @HJ66
there are quite a number of posts about voice call trouble.
Start with clicking Reset All Network on you phone and check if it hekps
If that does not get you back the voice call, create a support ticket with CS agent at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
03-02-2023 06:19 PM
There have been issue since yesterday for some people with both incoming and outgoing calls.
Try to change to 3G only and see if it connects to the network at all with such settings
If both incoming and outgoing calls are still not working, I suggest you to open a ticket with PM support and let them aware you are one of those, too
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
