03-07-2024
08:42 PM
03-07-2024
09:32 PM
Dunkman
My phone is all of a sudden in SOS mode. I can’t call, text or use my data and my plan isn’t expired yet. Where do I get technical support?
03-07-2024 09:31 PM
Try a reboot of your phone. If that does not work, network reset of the phone (Note: this will erase your saved wifi passwords).
You can also try your SIM card in another working phone. That would help determine whether hardware issue versus PM service problem.
Also, I would make sure that your phone was not blacklisted for some reason:
03-07-2024 08:43 PM
@Flow10 - Contact CS_Agent here:
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work go here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for an agent because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
