08-22-2026 02:59 PM
08-22-2026 06:11 PM
Even basic (cheapest) plan has unlimited Canada wide calls/SMS. More expensive plans have just more data.
Log in to your account and take a look...
08-22-2026 03:09 PM
You need to login and check
Login My Account on the browser, go to Subscription & Add-on page and it shows there
08-22-2026 03:06 PM - edited 08-22-2026 03:12 PM
If you have the app, you can go to subscriptions then manage subscriptions and then you can see exactly what you have! (Should also be the same on website)
