04-19-2024 06:49 AM
04-26-2024 10:31 AM
04-26-2024 09:07 AM
@Rick22 Can you receive phone calls? If you can receive phone calls but can't get SMS text messages then that is a known glitch in the Public Mobile system and you need to contact customer service to fix it. That may also explain why you can't set the phone number. Submit a ticket at the chat/message icon bottom right of this page.
04-26-2024 08:48 AM
I ported in my old number. I went to Telus for assistance and they removed my old/physical sim. I suppose I could try to use it again although my eSIM from PM should be sufficient
04-19-2024 07:27 AM
@Rick22 Did you port in a phone number from a previous provider, or did you select a new number? If from a previous provider, does their sim still work?
