Phone not working
Blackhills
I updated my CC information yesterday. My next payment is not due until May 15, so everything should be ok... I cannot call out. No payments have been missed and my Data plan is not maxed out.
2 REPLIES 2
dust2dust
Are you on the $15 plan? Maybe you've used all your minutes.
There have been a lot of calling issues of late though with the device-selective roll out of volte here since late February. If you phone is 5G compatible then set the networks to LTE as suggested. You could test 3G as well in case there's some kind of network outage in your area.
hycm53
Try reboot the phone and if your phone support VoLTE then set your phone on it or LTE at settings.
