12-09-2019 03:26 PM - edited 01-05-2022 08:27 AM
It happens last week the phone is not working,try power off take the card off still not working can’t call out or my wife calls me go to the voice message right away.any one can help.
12-15-2019 09:27 PM
Check if you accidentally block the number which can happen!
12-09-2019 04:34 PM
If you have the $10 or $15 plan with limited call minutes, you may have used all your minutes for the current cycle.
| Data & Add-Ons | Amount Used |
$0 Free Holiday Giveaway: 1GB Add-on | 0 / 1024 MB |
$0 Free Holiday Giveaway: 400min INTL Long Distance (incl CA & US) | 0 / 400 MIN |
50 International Outgoing Texts and Unlimited Incoming Texts | 6 / 50 Unit |
500 min Canada-Wide Long Distance | 0 / 500 MIN |
Limited Canada-Wide Talk | 12 / 50 MIN |
12-09-2019 04:13 PM
@Johnfung wrote:It happens last week the phone is not working,try power off take the card off still not working can’t call out or my wife calls me go to the voice message right away.any one can help.
That is strange. Is your account active? You also can click the "?" in lower right side of the page to talk with moderator and receive assistance. Type 'contact moderator" then follow directions. The moderator may help you with your case.
12-09-2019 03:32 PM
I would message an MOD directly. They would likely be able to help you!
Use this link:
12-09-2019 03:29 PM
Sorry your phone isn't working. We need a little more info to figure out what's going wrong.
Can you log into your self-serve and let us know what the account status is? Here are the steps:
If so, that will rule out that it's an account issue, in which case we can move on to figuring out if it's a SIM issue or phone issue.
12-09-2019 03:27 PM
What plan are you on?
Maybe incoming you have do not disturb on?
