4 weeks ago
My phone is not working for calling or receiving calls my son tried to call me and other people also it rings on their end then goes to voicemail I dont hear ringing on my end I cannot phone anyone it doesnt do anything when I call people
4 weeks ago
did you try your sim card on another phone?
What phone do you have?
If your phone is not on PM's VoLTE whitelist ( https://www.publicmobile.ca/en/on/get-help/articles/volte ) , then it will be using 3G for voice and it might be affected by this:
Telus is currently refarming the 850MHz band 5 spectrum and hence you are left with 1900MHz for voice calls.
https://www.publicmobile.ca/en/get-help/articles/850-turndown
While one compatible band is still sufficient, reality is 1900 MHz could have less coverage, depending on your proximity to a tower and hence you are seeing a poor or no coverage with voice (Data is not impacted as your phone has the compatible bands on 4G/5G)
If this is really what affecting your voice calls, there is really nothing much you can do other than getting a phone that is on PM's own VoLTE whitelist.
