10-22-2018 02:27 PM - edited 01-05-2022 02:15 AM
Did a plan change yesterday and now the i cannot make any phone calls, use data, text. It says my account is still activate and not payment is required until Nov 19th, 2018.
Can someone contact on 204xxxxxxxxxxx since my phone isn't working. CTN is 204xxxxxxxxxxx
10-22-2018 03:58 PM
Let's call it a feature to get more ppl involved in the community.
@Anonymous wrote:
I'm declaring right here that it's a designed-in feature 🙂
10-22-2018 03:18 PM
@mimmo wrote:@jessiefitkowski great to see the trick worked. @
10-22-2018 02:56 PM - edited 10-22-2018 02:59 PM
10-22-2018 02:55 PM
THANK YOU! The report it missing/stolen and found trick works.
10-22-2018 02:40 PM
Just wondering @jessiefitkowski
Which plan did you have before and which plan did you change to?
Some details might help.
Have there been any other changes since then? like a network update or software updates?
The more detailed information the better people can help.
10-22-2018 02:39 PM
Account says it's active.
I will try your suggestion. Thank you
10-22-2018 02:35 PM
What does account status say?
Try putting phone in lost stolen mode for 5 minutes the click found phone via self serve.
