Phone not accepting calls or Texts
GETITGIRL
My phone has not been accepting calls or text and I can't make calls or texts and my data isn't working. Is there a service outage?
GETITGIRL
Looks like there's a service disruption in my area.
dust2dust
Did you check your account to see if it's active?
https://www.telus.com/en/bc/outages
@GETITGIRL  Try rebooting the device or reset net work settings se if the helps and here check
Outage   map in your area:
https://istheservicedowncanada.com/
