Phone no more working
07-18-2020 09:18 PM - edited 01-05-2022 12:29 PM
After I changed to the new phone number my phone didn’t work anymore. What can I do? Thanks
Service
07-18-2020 09:33 PM
@manhtran88 hello put your phone in airplane mode for five minutes then restart phone
07-18-2020 09:30 PM
@manhtran88 try restarting your phone, remove and reinsert the SIM. Wait 5 minutes and restart it.
By change your number, did you transfer/ port from another cell provider? If you did, it can take up to 3 hours to complete, if from a landline or voip provider uo to 7 days. If its been longer than 3 hours and you ported from another cell provider. Your port may be stuck. Contact the moderators and ask them to fix it for you. There are 2 ways to contact the Moderator Team:
- Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
- Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
Welcome to PM .
