Phone in SOS mode
Bumps
recently activated PM via eSIM
phone always displays SOS mode.  Cannot make calls?
Would it have been better to get a physical SIM card or is it just PM reception that is the problem?
7 REPLIES 7
CSA_PM
Customer Support Agent
Hello @ Bumps,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
Bumps
Thank you for trying to help 😉
I will contact PM support
ORNGNBLK
@Bumps  Please reach out to PM for assistance then. Perhaps they can look into it from the back end. Open a ticket using the orange chat bubble on the bottom right. Hope this helps you
Bumps
Reboot.   And turn on this line is and has been selected on
ORNGNBLK
Ok, try this. Reboot your phone, then in cell settings (iPhone) make sure “turn on this line” is selected.  See if that helps, and let us know.
Bumps
It’s a new phone and new activation with PM
did not port anything over from old phone or carrier
ORNGNBLK
@Bumps  If you Ported in from a different carrier, please check that PM eSIM is set to primary and the old one is off.
