07-02-2019 10:38 PM - edited 01-05-2022 05:41 AM
Hello,
I just transfered to Public Mobile and my bq Aquaris E5 (which according to the MP webpage is compatible with their network) does not connect. The SIM card works (tested in another phone) and the phone is unlocked (tested it with another sim card). Any ideas why is not working?
Thanks
07-03-2019 12:16 AM - edited 07-03-2019 12:17 AM
@shalekash wrote:Does PM not have GSM 2G, 2.5G. I have seen it here, for example:
They have that wrong for years. People tell them they're wrong but won't fix it. You can live without LTE but phone must be 3g compatible with Public.
07-03-2019 12:06 AM
@shalekash wrote:Hello,
Thanks
According to the device checker on the PM homepage your device is not compatible. It seems that your third party site is wrong in this case.
07-02-2019 11:42 PM - edited 07-02-2019 11:43 PM
No. Only one carrier has those frequencies. And they're being phased out too.
07-02-2019 11:40 PM
07-02-2019 11:02 PM
Thanks
According to a PM moderator on this thread, PM uses the following frequencies
Public Mobile works on following frequencies:
According to https://www.gsmarena.com/bq_aquaris_e5s-7837.php, your phone does not support PM 3G which is used for voice call and your phone does not support any PM LTE frequencies.
| 3G bands | HSDPA 900 / 2100 |
| 4G bands | LTE band 3(1800), 7(2600), 20(800) |
07-02-2019 10:59 PM
Thanks
@shalekash If your sim card works in another phone and not your phone the problem is your phone. Maybe try a factory reset and see if it connects. If it still doesn't connect Thein your phone is not compatible.
07-02-2019 10:44 PM
@shalekash Does anything work? does pm how up In top left corner of your phone ? if you dial *611 what does it say?
07-02-2019 10:42 PM - edited 07-02-2019 10:44 PM
