07-18-2022 07:56 PM
Changed provider. Stupidly ticked port the phone number.
Text, apps, voicemail retrieval all works. Phone is not
answerable and does not ring.
07-18-2022 11:06 PM - edited 07-18-2022 11:08 PM
If your phone does not ring, check your setting to see if Do Not Disturb is enable.
If it is, just disable DND setting.
If not, put the SIM into another phone to see if it works. If it rings, good chance it is your phone that is the problem.
07-18-2022 07:57 PM
