11-16-2019 10:23 AM - edited 01-05-2022 08:00 AM
I understand Public Mobile's setting for 3G is 850/1900 MHz. My device shows 2100/850/1900 MHz. Will my device still work on PM's network? Please advise. Thanks, Gord
11-16-2019 11:19 AM
@gordsabean , 3G bands are definitely covered. If you are interested in the LTE bands, check out this wiki. With so many new phone brands becoming readily available, the phone compatibility checker is becomes somewhat useless. Best is to find the phone specifications from the oem website and compare manually to the supported bands.
11-16-2019 10:57 AM
It should work. You can check phone compatibility by going to PM home page and clicking on GETTING STARTED. From there click on PHONE COMPATIBILITY and follow instructions.
11-16-2019 10:39 AM - edited 11-16-2019 10:39 AM
@gordsabean Yes it will work without any issues.
11-16-2019 10:27 AM - edited 11-16-2019 10:29 AM
Depends on what you're trying to do really.. for simple use (calls and texts) you ll be fine. But to use the web you'd need access to more bands.
Edit.. didn't see the 1900 lol.. ur good to go 👌 😎
11-16-2019 10:26 AM
@gordsabean it should, what kind of phone is it? You can also check it on willmyphonework.net
11-16-2019 10:26 AM
