Phone compatibility
Zootius
I just got an UleFone XArmor 13. It's got 12Gb ram 64 + Gb, night vision, shock and water proof, etc.  it's a great phone in every way but for some reason I cant use mobile data for internet.  I've confirmed the APN settings and the critical ones are correct. Maybe the others should be blanked out?  Any suggestions would be helpful.  Thanks!
1 REPLY 1
Chalupa_Batman
Enter your IEMI number at the bottom of hte page.
https://www.publicmobile.ca/en/get-help/articles/volte
