01-27-2020 07:27 PM - edited 01-05-2022 09:13 AM
Which of these phones are compatible with Public Mobile Canada's network? How good is the connection going to be? (is the compatibility decent) thanks in advance
Samsung Galaxy A20 - SM-A205U:
https://www.newegg.ca/p/23B-0002-00E43?Item=9SIAKBDATM8490
Xiaomi Mi A3 Dual Sim - SKU: CMOBSAM01057:
https://www.eglobalcentral.com/xiaomi-mi-a3-dual-sim-4gb-64gb-more-than-white-1.html
Samsung Galaxy A20 - A205G:
https://www.eglobalcentral.com/samsung-galaxy-a20-a205g-3gb-32gb-dual-sim-black-1.html
Phones
03-28-2020 12:32 PM
I think you have answered a question I was going to post.
Searching for a cheap android *With Google Services* The problem has been finding a phone with 3G AND Google Services.
I've found a few Huawei Mate 30 Pro(s) that have Google Play but seem to only have 4G and not 3G in their description.
The phone is compatible in principle but every phone has slightly different features: https://apn-canada.gishan.net/en/apn/public-mobile/huawei-mate-30-pro
Am I correct in assuming TALK will not work on a 4G only phone on P.M.?
**Note my plan is the $25.00 for 30 days.
02-03-2020 09:51 PM
A good place to start is a site from ... Spain
It lists thousands of phones and their country compatibility (not only for Canada)
01-28-2020 03:17 AM
@hbn3141 You need 1900 and 850MHz for 3g to have voice service. That can be used for data too.
01-27-2020 08:04 PM
@hbn3141 . Follow this link https://www.publicmobile.ca/en/bc/get-started and scroll down to find out if my phone is compatible and check them. You can also use this link here to check each phones level of compatibility https://www.frequencycheck.com. Welcome to PM .
@hbn3141 wrote:Which of these phones are compatible with Public Mobile Canada's network? How good is the connection going to be? (is the compatibility decent) thanks in advance
