12-14-2024 12:17 AM
I got an iPhone 16. So I wanna keep my plan with public mobile but it won’t let me transfer my number
12-14-2024 01:03 AM
@Santiagomiyamo wrote:Would I be able to keep my old phone number
Yes, you keep your cell number.
12-14-2024 12:58 AM - edited 12-14-2024 12:59 AM
Yes you keep your number
12-14-2024 12:56 AM
12-14-2024 12:50 AM - edited 12-14-2024 12:53 AM
@Santiagomiyamo wrote:My iPhone XR is the one that has the phone plan with Public Mobile. I wanna transfer my plan from my iPhone XR to my iPhone 16. However it says that my iPhone XR is to old to do so.
take the sim outta XR and put it in 16...voila !!
download the PM app on the 16 and log in to your account , buy a new esim.
12-14-2024 12:41 AM
12-14-2024 12:37 AM
Maybe try updating the phone if there an update from Apple.
12-14-2024 12:34 AM
So it thinks a iPhone 16 is a older model?
You can contact PM below but you won't get a response till tomorrow.
12-14-2024 12:30 AM
I have a eSIM. It’s says my iPhone XR is to old to do transfer so I need to contact public mobile
12-14-2024 12:28 AM
Need a little more info. Using a sim card or esim? What do you mean it won't let you transfer. Are you getting an error message
