10-21-2020 09:26 PM - edited 01-05-2022 05:18 PM
Hi my phone is HUAWEI Mate 30 Pro (it's not on the phone list)
I cant receive phone calls at all....my friend called me and it's always busy. BUT I also tried it on IPhone 6 and still couldn't receive phone calls. Please help !
10-22-2020 04:05 AM
@hwang279 try dialing ##21# and ##004# to reset your call forwarding. maybe it's forwarded to a busy signal?
10-22-2020 01:20 AM - edited 10-22-2020 01:20 AM
@hwang279 by chance is your mate pro dual sim? If so, a long shot, but try the other sim slot.
10-22-2020 12:59 AM
Outgoing calls is fine. Just the incoming calls got busy line😂
10-21-2020 11:53 PM - edited 10-22-2020 12:04 AM
@hwang279 hi there, were you porting your number from another provider? if so, It can take up to 3 hours to complete if from a cell provider. When porting you can make calls and send texts immediately. The last thing to complete is receive calls and texts. If it’s been more than 3 hours and you ported from a cell provider. Then your port is probably stuck. Good to hear you already submitted a ticket as you need a moderator to fix it for you.
Welcome to Public Mobile!
10-21-2020 11:36 PM
@hwang279 standard response time for moderators is 24/48 hours usually quicker though.
Keep an eye on your inbox. Envelope top right ish on these forums. That's where they will reply.
10-21-2020 11:31 PM
Thanks! I already sent my request. Do you know how long does it take them to respond?
10-21-2020 10:51 PM
@hwang279 The Huawei mate 30 pro is compatible with Public Mobile. Best to submit a ticket and ask PM to investigate or reset your account.
10-21-2020 09:28 PM - edited 10-21-2020 09:30 PM
@hwang279 wrote:Hi my phone is HUAWEI Mate 30 Pro (it's not on the phone list)
Do outgoing calls work? The fact that callers contacting you hear a busy signal means that this likely isn't a device issue as people should still be reaching your voicemail box.
