yesterday
Hello, I can't make it receive phone calls anymore. This started yesterday. My data still works.
yesterday
@IvanK yes, 3G is shutting down in Manitoba, probably already shut down in your area:
https://www.publicmobile.ca/en/get-help/articles/3g-shutdown
yesterday
Yes, I am in Manitoba. I do believe that it has to do with my old phone and 3G.
yesterday
@IrinaBich you didn't give any details and you cannot just comment saying it is a common issue with different phones
Please tell is what phone you have, what you tried and which area you are at. Most importantly, what problem you have, voice? Data??
yesterday
No , its common problem now with different phones
yesterday
@IrinaBich do you have voice issue or data?
What phone you have? You are in Manitoba??
yesterday
Isn't up to you phone , its mobile issue
yesterday
The same problem here
yesterday
The same problem with my wife phone , started yesterday.
yesterday
yesterday
I can't figure out how to change those settings. I can't find them.
yesterday
No outages showing. My wife has the same brand of phone (umidigi ), she was having issues yesterday, but is working today.
yesterday
VoLTE is turned on in my settings.
Preferred network type is set to " 5G (recommended)"
yesterday
i did restart the phone , and did a reset. no change
the imei came up with
check mark - for VoLTE Network
- 5G spped
- E sim
Not sure what I am looking for ???? Sorry
yesterday
And I have a Huawei P20, so it is quite an old phone.
My brother has also heard of similar situations in the last 2 days from people that are from different service providers as well.
yesterday
hi @IvanK
if the IMEI checker says the phone is not compatible, then the device itself could be the issue, what phone is that?
yesterday
I restarted my phone. I also did a network restart. I have been trying to talk to a PM agent. I am waiting for a response. I also tried using the IMEI checker, but it was saying that my phone wasn't valid or something.
yesterday
hi @jb66
did yo follow what I suggested above? did you check the IMEI checker?
and check if any Telus outage:
https://www.telus.com/en/mb/outages
or you can ask PM support agent to refresh your account
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
yesterday
Hi IvanK,
I too have the same issue. I noticed it this morning. Please let me know if you find a solution.
Thanks
yesterday
hi @IvanK
try reboot the phone and reset network settings
and what phone do you have? check if your phone can access VoLTE on PM network using the IMEI checker here:
