03-30-2023 11:29 PM - last edited on 03-30-2023 11:32 PM by computergeek541
03-31-2023 12:03 AM
Please note that you don’t need to activate your phone…only activate your SIM.
Did you purchase the phone privately?
Are you referring to unlocking the phone?
03-30-2023 11:58 PM - edited 03-30-2023 11:58 PM
@softech wrote:@Jrmmcm455 what paperwork tells you that?
you are looking to activate a new phone line/account?
PM is a self-managed phone company. If you need to activate a new account, just get a new PM sim card first. Once you got the sim card, then activate the account from https://activate.publicmobile.ca/
I'm thinking that this isn't an issue with activating the SIM card because the information on the SIM card pacakging doesn't make any mention to contacting customer service to perform the activation.
03-30-2023 11:33 PM
03-30-2023 11:32 PM
@Jrmmcm455 wrote:My paperwork says to contact you to activate.
Which paperwork are you speaking of? Did you activate Public Mobile at a store last year (or earlier) but you need a Self Serve account created. To create a Self Serve account, a customer support agent needs to be asked for help. This is done by opening a ticket in the chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
