09-16-2022 03:13 PM
Hello, I need help setting up a phone number after inserting a sim card from public mobile
09-16-2022 03:33 PM
open a ticket with PM CS_Agent. at : https://publicmobile.ca/chatbot.
type: Contact Us and Other
Finally Click here to submit a ticket
If you have error submitting a ticket, send a private message to the CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
09-16-2022 03:19 PM
@HeYuzhen So have you actually gone through the activation process because you would have a chance to get a new PM number during that process, I'm sure?
Here's a link to activate a new account if you have your PM SIM:
09-16-2022 03:18 PM
@HeYuzhen did you activate via activate.publicmobile.ca ? during the activation process, you will be given a choice to pick a new number or port in from another provider
If you already completed that, can you make calls? or is it showing it connected to PM network? Any error on top of the screen?
09-16-2022 03:18 PM
@HeYuzhen ok are you porting a number fron another provider or taking a new number?
09-16-2022 03:16 PM
I believe that I would be activating a sim
09-16-2022 03:15 PM
@HeYuzhen hi are you activating a sim,and porting a nimber?
