Phone Number Port issue
GinnyHunt
got a text saying click contact us and complete sim activation.
please ensure you provide the correct account number from previous provider, but i can't find the change number button or the contact us button...
phone didn't port correctly.
@GinnyHunt wrote:
Thanks talked to my old provider and foudn out why it was rejected...
Sent a PM with the extra data...
Thanks
Sounds good. Also, in the meanitime while waiting for the port to complete if you wish you can continue to use your old sim to make/receieve calls. Once your old card stops working it means that the port is complete. Just insert your Public Mobile sim card at that point and everything should work including receiving calls and texts.
Take care.
GinnyHunt
Thanks
geopublic
@GinnyHunt  Means that there is an issue with your port request. Click here and provide the correct account information.
The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message provide the required info and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderator Hours: Monday-Friday 8 am(Eastern) to 12 am(Eastern) and Saturday, and Sunday from 8 am(Eastern) to 10 pm(Eastern).
Hope this helps!
Alex888
@GinnyHunt To contact the moderators you can send them a private message here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
They are very busy right now so it may take a couple of days for them to respond.
