Phone Compatibility not working
Jennixie
Drop down boxes empty when looking for phone compatibility...  Tried Safari and Chrome on mobile and computer.  Looking to see if NOKIA 5233 is compatible for a text/call phone for my kids.  TIA!
2 REPLIES 2
dust2dust
That phone is not compatible here.
Yummy
You are correct, that feature on PM site does not work.
PM uses these frequencies so as long as your phone can handle them, you will be OK.
Public Mobile uses the following frequency bands:
4G LTE and LTE Advanced: 700 MHz, 850 MHz (band 5), 1900 MHz (band 2) and 2100 MHz downlink and 1700 MHz uplink (AWS).
HSPA: 850 MHz, 1900 MHz (UMTS).
Check these 2 sites. Pick Telus...
https://www.publicmobile.ca/en/on/get-help/articles/check-your-phones-compatibility
https://willmyphonework.net/
