Phone Compatibility - iPhone 5S from France - ME437F/A -
Funtou
Hello,
I have an iPhone 5S from France with a current plan with Fido.
I'm looking to switch to Public and would like to confirm phone compatibility.
Here the details:
Model Name: iPhone 5S
Model Number: ME437F/A
Thanks a lot! Hope I can join the community 🙂
7 REPLIES 7
@gpixel wrote:
@Funtou yes this phone will work. make sure you get it unlocked from fido before proceeding
If the phone is from an authorized retaiiler in France, it wouldn't be locked to Fido. It would already be unlocked since it's already being used on a network other than the original.
@Jb456 wrote:
Freedom uses band 66 which maybe that's why it did not pass as I don't think your phone has that band.
Freedom Mobile customers do not absolutely need Band 66 compatibility to use the service. While it's idea ot have it, I would say that Freedom Mobile's primary service is still provided over HSPA and on band 4. They also now have LTE available on LTE bands other than band 66. On that note, Telus Mobility also uses band 66 for LTE.
Funtou
Awesome! Just did and it recognizes it as the iPhone 5S A1457 - thanks everyone 🙏
@Funtou
Since public mobile is owned by Telus try Telus compatibility checker. It uses your IMEI number.
https://mobility.telus.com/en/ON/phones-and-devices/devicecompatibility.shtml
Don't forget to use a referral code for a $10 signup bonus!
Funtou
Sounds good, thank you so much, asking since this phone didn't pass Freedom phone compatibility.
tabi159w
This phone will be compatible with Public Mobile, especially since it works with another Canadian carrier. As long as it's unlocked it will work fine.
gpixel
