11-19-2022 06:04 PM
Since paying my last phone bill, I’m not able to make or receive phone calls. I’ve done all of the things the helper suggested and forum, but it’s still not working. I have an iPhone 6 right now, and unlimited calling and texting with data included.
Service
11-19-2022 06:10 PM
@01christinelam Have you recently logged into your account and check out if your plan is still active or suspended?
Try calling 611 and check out the status from there too.
11-19-2022 06:09 PM
Hi @01christinelam , you just renewed this week? there have been many posts with similar problem. I think you need to open ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
