06-29-2016 10:29 AM - edited 01-04-2022 12:55 PM
I was wondering if an unlocked iPhone 5S model A1533 (CDMA) will work on PM? The specs say it supports LTE cellular. I did the IMEI checker and it said no but wanted to double check to confirm. Thanks!
06-29-2016 02:20 PM
@LHBC You may have a first from the IMEI checker. It is not always correct but the usual error is "may work" when a phone won't work. Yours will be the first I have seen that is reported "won't work" when it will.
Our other "go to" source (again not always correct) is http://willmyphonework.net which is reporting that both models will connect to PM's 3G network, but only partially on the LTE network; partially means only 1 of the frequencies is supported so reception is "spottier".
What is absolutely certain is that the phone will not function unless unlocked. You may also find these two articles instructive: http://www.cnet.com/news/switching-carriers-you-may-be-able-to-take-your-iphone-5s-with-you/ and http://www.everymac.com/systems/apple/iphone/iphone-faq/differences-between-iphone-5s-models.html Apparently the CDMA version was sold through Verizon and will be locked to them, unless someone went to the trouble to have it unlocked.
We will all be interested to learn how you make out.
Good luck.
06-29-2016 01:30 PM
Thanks for the clarification...yes the phone does have a nano sim slot. I will get a PM sim then.😀
06-29-2016 01:15 PM
@LHBC Hi all; all iPhones have a SIM card slot. The quickest compatibility test is the following:
- Get a PM SIM (they're free) and look at the message on the phone when it is installed. Even if not yet activated, it will say "No Service" if the phone is compatible with PM's network. If it says "Enter Code", then the phone is not unlocked. If its says, "No SIM" likely the SIM or phone is defective.
iPhones must be unlocked or purchased from Koodo/Telus to connect to the PM netowrk.
You can read more about compatibility here.
06-29-2016 11:46 AM
Yes, that is what I meant, that this model does not appear to use a removable sim card. As @Shazia_K stated, that can be confirmed if there is no sim card slot on the phone.
06-29-2016 11:32 AM - edited 06-29-2016 11:54 AM
Hello @LHBC,
To add to what @JaK said, I think he meant that, this phone does not accept a SIM card, meaning there is no SIM card slot. Can you confirm if it does?
Looking at the phone specs and if you confirm that a SIM card could be used on this phone, this phone should be functional on our network after being unlocked.
I hope this helps?
Shazia
06-29-2016 11:22 AM
I do not have a sim....thanks for your reply....not the answer I wanted...😞
06-29-2016 10:40 AM
Taking a quick look at the iPhone 5s models I found this:
The implication is that this phone doesn't have a sim card, does it? If it doesn't, then I don't think it can be made to work with PM.
