People having porting issues
11-17-2016 06:25 PM - edited 01-05-2022 12:32 AM
I'm just curious, for people having porting issues, are you using your IMEI number for the port and, if so, where are you obtaining the number from on your phone?
Service
11-17-2016 06:41 PM
Okay, I guess that blows that theory... 😕
11-17-2016 06:40 PM
Yea the numbers are the same
11-17-2016 06:39 PM
It only asked for the phone # and the account # from the previous provider.
11-17-2016 06:39 PM
Okay, this is good to know. I've done a few successful ports so far using the account number and the IMEI.
11-17-2016 06:37 PM
When you type *#06# into the dialer, does it match the number you used for the port? or is that where you obtained the number?
11-17-2016 06:36 PM
I've been telling people to use the account number and nothing else. 100% success rate so far 18 people ported
11-17-2016 06:35 PM
Yea used imei and been waiting like almost 30 hrs now still only partially done.
11-17-2016 06:34 PM - edited 11-17-2016 06:36 PM
Always get the number from your dialer by typing in: *#06#
The number on the sticker or in settings isn't always correct.
I'm just wondering if this is what's causing a lot of these issues.
11-17-2016 06:32 PM
There are 3+ ways to find the IMEI number on your phone!
- on the back or where you put your SIM card in
- by dialing *#06#
- in your setting
11-17-2016 06:30 PM
Don't even have the option to get past the check number :3 Tried different browsers and have waited to the next day. I have pm'd the mods and sent a support ticket though.
11-17-2016 06:26 PM
Yes and yes
