Payment
PetroG
I have noticed that my credit card was also charged twice in January and now in February.
2 REPLIES 2
hi @PetroG
if the payments show up twice on your credit card in Jan and also twice in Feb, you can check with PM support agent, not sure if you have activated 2 accounts by mistake
if same, then submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
@PetroG
Where you see the double billing?  Were they on the credit card or were they on the Payment History on My Acocunt (https://myaccount.publicmobile.ca/en/account/payment/payment-history ) ?
If you see them on your credit card, check if one of the charges is just a pending charge while only one of them is the posted charge.
If they are on Payment history on My Account, please note that each renewal will show at least two transactions on payment history on My account.  Only one entry shows actual PM charge, show how much PM charged your card and applied the amount to your Available Fund in My Account.  The other entry, likely couple hours later on the same day, will be showing how PM uses the money from your Available fund in My Account for plan renewal.
Post us a screenshot of you have any question.
If you are certain there are more than one posted charge (and not pending) on your credit card and you cannot find where the extra money went, engage support for further investigation:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
