Payment
An-Go
I paid $22,60. Can I download your app now?
Socrates8567
@An-Go wrote:
Thanks a lot!
I changed the country, downloaded the app and got the new number with a eSIM.
My new question:
Can I keep my new number without paying for 2-3 (next) months, and then to pay again for just one month?
Simple answer, YES!
An-Go
Thanks a lot!
My new question:
You need to change your country to Canada to download the app
Are you activating new account with physical sim? PM can help if so. Please use the link in my post to message PM
Socrates8567
@An-Go wrote:
« App not available in your country or region »
Hello
This error happens because your app store or Google Play account region is not set to Canada, but the app is restricted to that region. To fix this, you can temporarily change your account's country to Canada, use a VPN with a Canadian IP address, or have a friend with a Canadian account download the app for you to use to activate your service.
An-Go
slusagm
You can always download the app even without paying.
What error you got?
Or ask PM to help
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
