Payment voucher
145step
*611 will not let me redeem my payment voucher
7 REPLIES 7
@145step wrote:
*611 is not letting me redeem the voucher. There is no option to do so.
Oh, are you perhaps trying to activate a public mobile SIM Card @145step . Apparently this option is not available any longer.
If you are trying to activate a sim card, then see @RossN to submit a ticket with customer support for assistance to do this, by the method # 2 listed:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Payment-voucher/m-p/860922/highlight/true...
edit, wait, i don't think the above is the case...as you seem to be trying to top up with 611...well, what message are you receiving?
NOTE:
If you have been in nonpay/suspended status for over 90 days, then you lost your Public Mobile account, phone number, and access to self serve.
@145step
turn off device and take your SIM card out and reinsert back on,
and see the photo  about call *611
145step
145step
RossN
@145step hi some vouchers won't activate for up to 24 hours maybe try again later or try to input it in your self serve account alternativly you can
contact a cs agent to input it for you
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
Timer
@145step
from which store you buy it? some voucher need 24 hr to Activated.
Timer
@145step
call *611
once connected press (1) then (1) again and enter the 12 digit PIN #,
or
tried use browser from computer, clear cache and cookies and use one page inPrivate mode,
To Login Page
and go to payment,,, voucher and add it 12 digit PIN #,
