Payment not working
eparlier
Using a master card gift card, tnought it would work? Can't we pay with master card gift or debit card? I wait 24h to make sure the card was activated...
11 REPLIES 11
Just a follow-up..."Payment Methods" returns options, as you said. ...but "payment methods" is confusing to Simon. Go figure !
eparlier
saved my ass
recharge.com -> paypal worked with my gift card thanks nothing else worked
@eparlier wrote:
There are no physical store where I can buy voucher cards in my area 😞
Also to point out that ther are no "physical" Public Mobile stores. Walmart, London Drugs, Wow and The Mobile Shop are just a few or try the other options that was previously mentioned.
Not sure exactly what you are looking for but if you type "What cards can be used for payment" into Simon , the orange ball with the "?" in your bottom right corner it will give you payment options.
If either response to your particular request leads to the resolution of your issue , please help other community members by marking that post as the solution. Thank You
eparlier
krazykiwi
@eparlier According to Simon, it will accept Visa debit cards only.
@hairbag1 "Payment Methods" didn't work for me, had to ask "What cards can be used for payment"....that returned a very good answer.
KMG
They charge fees, but no taxes.  Depending on which province you live it, it can be very close (or even cheaper).
austinhuang
@KMG wrote:
You could try recharge.com
Use the Mastercard gift/debit card through Paypal.
Recharge.com takes 10% fees.
Since you can use Mastercard gift/debit card in stores it's better to do it in physical stores.
KMG
austinhuang
Mastercard Debit (e.g. BMO debit cards) will NOT work.
You could just buy a voucher from a store.
If this solves your question, please select my reply as Solution!
hairbag1
Use Simon the chatbot in the lower right side of the screen (Orange coloured ball) and type in "payment methods". That will give you options and step-by-step instruction. Good luck.
