07-12-2022 10:59 AM
Hi, I'm having a problem adding my new credit card to my account which expired because I lost my old credit card. Every time I try to put it in my new information, I get a notification: "Unable to process transaction. Sorry, your credit card was denied by your card issuer, so this purchase could not be completed. Your credit card has not been charged. Please contact your card issuer for more information." This happens despite the fact that my card has been working for other purchases. I also tried to use my mom's credit card and got the same notification. Then I bought a prepaid voucher from a gas station to pay, but the voucher also did not work. I think there is a problem with the website? And I'm not sure what to do. Thanks for any help.
07-12-2022 03:39 PM
@mariah0 No worry, important thing is , you are back online now 🙂
07-12-2022 02:52 PM
@hairbag1 @dust2dust @softech @MrSpock Thanks for all of your help! The problem ended up being that I didn't put in the correct mailing address connected to my credit card. I moved recently and updated my address but thought I still had my old address on my account. I feel really silly, but at least the issue is resolved now.
07-12-2022 11:54 AM
If the voucher had multiple sets of 12 digits then did you use the one called PIN? Could you also try to enter it in the 611 system?
07-12-2022 11:48 AM
@mariah0 wrote:Thanks for the suggestion. I bought a voucher and tried to add it to my account, but it didn't work for some reason. I double-checked the number but it still didn't go through.
@mariah0 where you got the voucher from? Has it been a full 24 hours since you purchased the voucher?
Vouchers from some store has a wait time of 24 hours, they need to sync with PM system and it's not done yet
07-12-2022 11:42 AM
07-12-2022 11:41 AM
Thanks, I'll try that
07-12-2022 11:35 AM
@mariah0hi if you are having that many issues contact a cs agent and get them to input manually you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
07-12-2022 11:29 AM
I suggest you buy a voucher or use real time payments to get your services back up. Then you can take your time to figure out what's going on with the credit card.
The address needs to match the billing address. No space in the postal code or don't use the last #. Maybe even all caps.
07-12-2022 11:21 AM
I removed my old credit card already, and I have been double-checking the info each time I try it including making sure my address is correct. I'm not sure what else to try next.
07-12-2022 11:09 AM
Make sure to remove old cc before adding new.
Double check all new cc info is correct.
If you try unsuccessfully too often, the process is blocked and you'll need to try again in a few hours.
07-12-2022 11:03 AM
It expired on July 9th. I tried to update my payment on that day and I've tried every day since but it hasn't worked.
07-12-2022 11:02 AM
Did your account expire more than 90 days ago ? If so...you'll need to start over with a new sim to start a whole new account.
After expired for 90 days old account is gone for good.
