08-07-2022 03:51 PM
I removed pre authorised payments and I was still debited for the following month. How do I fix this? I don’t want to use the service for the next few months.
08-08-2022 02:59 AM
@Joli123 wrote:I finally got a CS agent to remove my card, but they are refusing to refund the debited amount. If I disabled preauthorisation, they shouldn’t be able to charge me in the first place & if they did, the least they can do is admit the glitch and fix it. I’m very upset.
They can see if autoapy was on or off? Did the CSA say it was on? Contact them again. Sounds like the CSA didn't look at autopay status.
08-08-2022 02:38 AM
08-07-2022 10:47 PM
How did you remove authorized payments @Joli123 ? It'd be good to know in case there is a glitch with this method.
You may also call 611 from your device to remove the autopay option.
08-07-2022 04:26 PM - edited 08-07-2022 04:27 PM
@Joli123 Are you able to suspend your service using the Lost/Stolen option? That should be available under Quick Link right hand side of the page. But as already mentioned, make sure you pay before the 90 days suspension is over (recommended around day 86) to avoid losing both account and number permanently.
BTW, using lost stolen option also suspends any rewards and customer support is needed to add them back to your account once you reactivate.
08-07-2022 03:56 PM
08-07-2022 03:54 PM
You would have to turn off auto-pay.
You can do so by going to My Account > Payments > Manage Payment Method > Pre-Authorized Payments, and disable it.
As a side note, if you don't pay for 90 days, your account will be canceled.
08-07-2022 03:52 PM
@Joli123 you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
