Payment charge
06-11-2024 10:56 PM
06-12-2024 05:31 AM
@Oskar12 Unless you are on the old $15 plan there are some new plans available in your account when you log in that could lower your payments again. For example $19 for 1GB of data replaces the old $25 plan but at higher speed.
06-11-2024 11:20 PM
I guess you forgot about the notice from PM in March about the switch from the Legacy Rewards to the Points Rewards.
06-11-2024 11:12 PM - edited 06-11-2024 11:14 PM
Public Mobile has discontinued their old rewards program so you will no longer be receiving those rewards. You will be receiving the new points-based rewards instead which will need to be redeemed manually. For more information take a look at this help article about the change: https://www.publicmobile.ca/en/on/get-help/articles/move-to-public-points
06-11-2024 11:00 PM
@Oskar12 wrote:Why I don't get discount with autopsy and loyalty programs
Sorry, but there is no discount given for using autopay. There is also no lnoger any loyalty credit given every 30 days.
