Paying for LTE but getting no LTE only 3G
02-06-2019 03:41 PM - edited 01-05-2022 06:37 AM
My mom plan is the same as the entire family but for some reason her phones are only getting 3G. I tried to change phones and turn LTE on but nothing happens. The data is stuck to 3G.
Service
02-06-2019 07:48 PM
Try going settings -> cellular - lte turned on . If it's shut off iPhones won't use LTE for data.
02-06-2019 07:20 PM - edited 02-06-2019 07:21 PM
Hi @ChrisM7,
Are you talking to her on the phone while she looks at the screen and tells you what she sees? The reason I ask is that voice calls are always on 3G on this network.
iPhones support all the correct frequencies and technologies, so it's not a hardware issue. Have you tried airplane mode on/off to see what happens?
02-06-2019 06:50 PM
@ChrisM7 wrote:My mom plan is the same as the entire family but for some reason her phones are only getting 3G. I tried to change phones and turn LTE on but nothing happens. The data is stuck to 3G.
Hi,
I am not on a LTE plan but my iPhone 6 randomly displays "Public Mobile LTE" and Public Mobile 3g" and I stress the random part!
What is happening that you say it is stuck to 3g?
02-06-2019 04:29 PM
@ChrisM7 wrote:Ok will do that tonight hopefully that works. Thanks
@ChrisM7Did she just switch to public mobile? How long has she been a customer? Or was she using the iPhone6 on public mobile and LTE was working untill she switched phones?
*thinks* If the sim/phone switch proves the same result, I don't know this about public mobile as they are pretty new, but a problem has existed before where old version sim cards at other carriers were not LTE compatible. Not sure if maybe she has one of the first sim cards, and maybe those didn't support LTE, I was never at public at that time. also don't remember dates between nano/micro/normal sim and would think if she did have an ancient sim would it even fit without someone manually cutting it to fit? Iphonex uses nano. Also not sure if public mobile ever released a sim card that was not LTE compatible.... just talking out loud here.
02-06-2019 03:45 PM
02-06-2019 03:45 PM
@ChrisM7Try switching your sim card with hers, and see if your phone gets LTE with her sim, and her phone gets 3g with your sim. This will confirm any local issues
02-06-2019 03:45 PM
She had an iphone 6 previously but now an iphone x
02-06-2019 03:44 PM
What type of phone does she have? Does it support the LTE Bands?
02-06-2019 03:44 PM
@ChrisM7Thats a phone issue, not a public mobile issue.
I am on a 3G plan, but i still connect to LTE, (although its LTE at 3mb) The most likely case is the phone does not support the LTE frequencies of the telus network or a software issue.
What phone model is it? Be specific please.
