Password will not reset
darinmain-67
Tried reseting my password and it all me all the steps but at the end it won’t allow it to change it gives me a message of your error? What the use of a reset if it doesn’t work?
10 REPLIES 10
What are you needing to do? Are your services working? When did you last pay?
You can also use the reset password in that login screen (that looks a lot like the normal one). You can choose the sms verification method even with suspended service (as also with the normal one).
darinmain-67
Does not work
benfatto
@darinmain-67  Even without a desktop you can open an incognito session with your mobile browser. If you need directions to do that, tell us the browser you are using.
Try to test the login id using the chatbot. Click on chatbot (Simon) down below and chat with it and click sign in and test what you think the login should be.
darinmain-67
It does all the processes till the end then it will not accept the reset of password.
darinmain-67
Don’t have a laptop or desktop at the moment
HALIMACS
@darinmain-67
If you are attempting this on a mobile device, try using a desktop if one is available.
I tend to have better luck with PM related self-serve functions on a desktop.
Tsawwassen
Did you receive an authentication code?
gpixel
@darinmain-67
 the key step after resetting the password is one needs to open an incognito or private tab and then login with the new password
@darinmain-67 - you are a current customer (active service within 90 days and have not ported out), right?
Try using a different browser or a tab in incognito mode.
If still issues after trouble shooting, ask CSA for help.
­­­Public Mobile Representatives customer support­­­ agents (CSA) can be contacted by either two methods, found here:
