Password reset
David89
I recently reset my password, as I forgot it. Now when I go to my phone it says password change successfull. However I can't sign in it just repeatedly says login information incorrect. Any suggestions?
7 REPLIES 7
David89
Hey All,
Filed a ticket and it was resolved within the hour. Thanks for all the help.
@David89
tried use browser Microsoft Edg from computer,and clear cache and cookies and use just one page inPrivate mode,
then Reset Password
after says password change successful. close all browser, and again clear cache and cookies
and use just one page inPrivate, To Login Page
you will get verification code by email or SMS
and when you press the 6 digit number and not press anything
just wait a 5 second automatically be login,,
David89
Had to submit a ticket. Hoping to hear back from them soon. Thanks for your help tho, greatly appreciated.
Dilber7
I just had this problem, using a different browser helped, along with clicking the eye so I could see the password, realized I’d typed the wrong thing. If different browser doesnt help, doublecheck for spelling or case sensitive errors or change password again 🙂
HI @David89    you can try to reset password once more , but this time, do not login immediately.    Wait 10 mins and try login
If still fails, then open ticket with CS agent and have them to help:
To open a ticket with PM CS Agent. at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
David89
Hmmm, tried on PC in incognito, still nothing. Just getting the same message.  Saying email or password incorrect
will13am
@David89 , try login on a computer using incognito mode on the browser.
